I'm having a problem with my repop radiator core support. I bought a re-pop and there is a major alignment problem with it. If you will take a look at the photos you'll see that the bottom brace that goes across at the bottom and is bolted on to the very front of the frame will not line up. It appears there is a major QC issue in that area. I drilled out the holes for the bolts on the RH side (Pass.) side, but when I did manage to get the core support to bolt up, the whole front clip was twisted. Has anyone had this problem and if so, what did you do to fix it?
