1 - 9 of 9 Posts
Can anyone tell me want the difference is between the 62-64 and the 65? I can see from photos the area around the rad opening is a little different but is there a fitment issue if I want to use a 65 style on a 63.
The reason is the larger opening will clear the A/C fitting without cutting.
I'm not 100% sure on the rad support but I know the 65 has its on unique hood latch which bolts to the support so that may be part of the difference.
The brackets next to the headlights are different.
2 X on the brackets.
Also there is a different set of holes to mount the brackets which help support the gravel pan. This is the metal piece behind the front bumper and fills the lower space below the grille.
Bryan
1 - 9 of 9 Posts
