Have a Quick fuel 950 race carb sitting on my 421 that has a new set of pistons, a bigger cam, and Carb rebuilt by Holley. Have just got around to getting it together and have a tuning question on the carb. Car use is Strip/Street, I hit it with nitrous at the track, like a 250 shot but I have not got that far, still tuning for the street.
AFR is about 13.5 at idle and when off the throttle while cruising.
AFR is about 12.9 WOT, little lean
The area I want to clean up is when throttling up gently from idle thru 3K. Secondaries (mechanical with a 40% progressive linkage) are not in play at this point and the AFR gets pretty fat, like between 10.9 and 11.7.
I'm using 79/89 jets and have checked the Accelerator pump adjustment, also the bowl adjustment has been done as well. Oh yeah and the power valve is a 4.5 (61600).
My initial thought is to pull 2 jet sizes from the primary and +2 the Secondary bowl but that sounds like a big spread so before I go further does anyone have other suggestions for me?
ALSO
The vacuum checks out at 5 and the idle mix screws are at 1.25 turns with the idle set at about 1000 RPM. What is weird is the idle and vacuum picks up as I turn the screws in?
ALSO
