I'm replacing the weatherstrip and fuzzies on my 62 convertible which has the wide reveal molding. Got a couple of questions:
Should I use any kind of caulk or adhesive under the reveal molding? It's only held on by a screw on each end. It seems like water could get splashed up from the road under it and into the door insides.
When taking the vent window out to replace the seals there as well I could not get it out until I removed the 2 screws holding the reveal molding and then slid that out to the back. Then the vent frame came out easy. Do I need to kind of reverse that process or can I attach the molding then slide the frame down in the door?
