I am in the process of building my car and I want to run this thing on pump gas and push a max of maybe 12lbs of boost, from anyone's experience is a motor with 10-1 compression to high for a supercharger or should I play it safe and build it with 9.5-1.:confused: I do plan on running some high octane fuel if needed, but for the most part I want a 93 octane street beast. The engine is a 427 sbc with aluminum heads.
I ran 8.5 to 1 on my smallblock 385 chevy with afr 210 heads....I ran sunoco 94 with it .....imo i would run no more than 8.5 or 9 to 1 comp...Are you using a msd btm box on it?
I run the areomotive pump with a boost referenced regulator and a return fuel line back to the cell....as for ignition i run a mallory unilite with a msd btm box......10 to 1 compression is to much imo
