when i rebuild the top end for my 307 should i re use the stock push rods and rocker arms or replace them aswell?
well so long as your pushrods arent bent you should be fine if i were you i would get some roller rockers and ditch the stock stamped units
I would take the pushrods and roll them across a flat surface and make sure there not bent.Also clean them up and blow through them with compressed air.
As far as the rockers if you kept the pivot balls and rockers togother.And there in good shape they should be fine to.Thos pivot balls and the rocker wear togother and need to be kept togother.....
Good luck!
