I'm in the middle of installing a CPP kit, disc brakes and a dual master. My question is I'm going from a Power Drum setup to a manual disc setup and need to figure out where to get the brake rod and clevis for my new brakes.
I was going to use either a Wilwood master or Strange master, and order their mount kit, but after reading about using the combination valve and how alot of people feel it's necessary I'm swaying towards a master with combo valve, but they don't come with the rod and clevis.
Anybody out there do a similar swap? It's for my 63 Wagon.
Thanks, John
Is the brake rod and clevis included with the master, or available separately?
I think the rod is included with the MC, but the clevis will have to be purchased seperately (I think CPP has them).
Hey there. I'm not sure if the original will work or not but that car was originally manual brakes. I added the booster and I think I tucked the rod and clevis under the spare tire. check there first or in the box of parts I sent with the car. If you don't find it let me know because it has to be around here somewhere. I hope things are going well for ya.
Eric
Hey Eric! I'll take a look right now. I need to get some pictures of the wagon up. I think you'll like the way it looks.
That damn oil pan still leaks! I switched the gasket to a newer style, got the front to not leak, now the back leaks! One more time should get it done.
Yea the oil pan gasket is not one of my favorite things to replace. I pM'ed you about the rod/Clevis.
I can't find that rod/clevis, I've looked all over the place... ticks me off too.. I know I wouldn't have tossed it... I'll take one last look and let you know...
