I recently put a Type II power steering pump on my car. Never had power steering before. Its a 1 grove PS pump pulley. The engine is BBC short pump with the alternator on the driver side. So the problem is if I use 1 belt for the crank/water/alt, and the PS pump the PS pump doesn't get enough belt on it.
So the question is can I run the water pump and alt. on 1 belt and run a seperate belt on crank/water pump and PS. The crank and water pump both hve 2 groves. Do you need to run the alternator off the crank?
