I'm adding power steering to my 66 Nova V8. I have two pulleys that I'm unsure if they are correct for this application. The crank pulley is 3rd groove extension #2321573 and the pump pulley is #57132041. I'm pretty sure the numbers are correct, they are pretty greasy and hard to read.
Does anyone recognize these numbers?
Tnx Jim
Tnx Jim
No idea what the pulleys are that you have but not what ya want.
Crank pulley for V-8 is # 3751232 P/S
P/S pulley is # 3770509
Other pulleys may or may not be P/S but are 66 283/327 pulleys.....# 3755820 and Water / pulley # 3790356
All for 283/327 66-67 Nova
Hope this helps.
Dave
67 Nova Boy
I am also using the crank pulley # 3751232 on my GM crate motor. Its a single groove pulley that is added to the other two grove crank pulley.
My PS pump is from an early 80's camaro, and that pulley number is 93430150.
Thanks for the info. I'm having an alignment problem. PS pulley is about a quarter inch forward of the crank pulley. Probably need different pulleys.
Tnx Jim
