I’ve been chasing some driveline noise for a while at speeds over 60. I’ve fixed the pinion angle, new bearings, newer driveshaft and u joints. I put a stethoscope on the trans tail shaft with the car run in gear with the wheels off the ground and heard some noise. A little bit of a pulsating, grinding sound but not horrible sounding. I decided to drop my driveshaft to check the measurements to see if maybe there wasn’t enough inserted into the trans. Have a M20 trans 2.25” in the trans and 1.25” outside of the trans. Does that depth sound right?
Didn’t hear any noise from the diff with the scope either.
1.25" showing sounds a bit much, but I don't know if it's too much. When I had Denny's Driveshaft make my high performance shaft they wanted the yoke pushed in until it bottoms, then pulled out 3/4", then measure center-to-center on the u-joint cups for correct length.
I know if you get it out too far, the driveshaft can go into a "jump rope" kind of harmonic rotation forcing the yoke to wobble and it tears out the yoke bushing in the trans tail housing and eats a groove in the yoke tube....I had that happen with a BorgWarner Super T-10 trans
Is that measurement with the weight on the differential? you want to measure it with the suspension loaded. Also I would be looking into the tailshaft bushing if you think its making noise. There is a bushing that supports the yoke in the tail housing.
It is with the cars full weight on the suspension.
