dave ,
I bought that "black tool, for my new combo-valve" .... I DID-NOT use that.
Before you start (bench bleed u'r m/c), then with everything ready ---
start by opening the RR bleeder & let it gravity bleed. Keep u'r m/c topped off. When you get flow to u'r RR .... then gravity bleed the left rear ... before you even go "pumping anything".
Alot of people (including me), just start th'pumping , and get nothing or VERY little ......... save yourself some headache : by getting the lines flowing before u start bleeding.
ps : the RR may take a few minutes too start the flow , (let the RR flow for a few seconds , maybe get a few ounces), the LR will start the flow much sooner. Gravity bleed the Fronts, also ... be ready.
Now, for your "Combo valve" --- use your test light (install the clip on the light switch -- stick the pointed end on the + post) . When you start pumping -- the person doing the pumping watches the Test - Light.
Light IS OFF -- good to pump -- Light go ON -- combo valve is Tripped , easy !
TO Re-set your valve : remove that light switch ... use an 'ice-pick' type tool (small screw-driver) , and reset the valve. WHICH way -- have a flashlight look into combo valve -- you can tell -- just move "guts" back to the center position. reinstall light switch, then back to pumping .....
KEEP u'r m/c topped off .
(by removing the light switch ... (it has o-ring seals, on the slide-valve) ... IT Will - Not let Air into u'r system). ( unless you take all day !!! ).
some people make it hard (including me) ... I think, most guys only bleed their brake systems once or twice , in the life of their cars. It's Not hard, just don't make-it hard .
jim
ps : by using the 'Test light' ... "Wax-on ... Wax-off" ----- the light don't fool you. By '"gravity bleeding --- you don't spend hours .. bleeding / pumping.
It can take A Long Time to Fill those empty brake lines ... either front or rear .. or both .
I hope this makes sense ....
