What is the difference between a disc/drum and disc/disc proportioning valve? Do they have different residual valves built into the rear portion. If so I didn’t think you needed that for a MC amounted higher than the calipers...Just curious.
Vendor
Drum brake prop vaves have a 10# residual check for the rear brakes. It would make rear discs drag and heat up.
Tim
