Another learning moment along the way...fuel pump pushrods! Turns out not all cams are made of the same material. Im guessing everyone here already knows this or doesnt run a silly mechanical fuel pump anyway.
My last roller cam I had a chromoly pushrod in there, and it ground the pump lobe down. You can see the end of the pushrod is gross looking.
So the solve is a bronze tipped pushrod. Well....none in stock ANYWHERE. So I bought one for an oldsmobile block which means the pushrod is .200 longer and I shortened it.
Its working for now, and ill put the correct one on backorder.
