Hey all, the 1974 nova i bought has a ratchet shifter. It was an original column car until the shifter was installed.
Every time i want to start the car i have to play with the section of the column where the original column shifter was in order to (i assume) send power to the starter. turning the key by itself will not start the car unless i get that column piece just right
Is there any connection i can make or jump in order not to have to do this stupid ritual every time i want to drive? That piece is also very sloppy and easy to move.
Also, if i turn on the headlights and try to turn the lights on with the instrumental cluster, nothing happens, the flashers stay lit and the fuel gauge goes empty. Sounds like a ground problem but where is the ground for the cluster located?
