I developed a leak on the input of my third member on the nova that I drive for fun and take to cruises,. Started to drop the shaft to see about a seal replacement. WELL! I can wiggle the yolk even before I took the shaft down . I figure a seal ain't going to help the real problem. Does the problem sound like a bearing or what. The rear looks like an 8.2 10 bolt. I started checking on parts tonite. The rear had a little whine when you backed off the gas, but was quiet under a pull. Does that sound like too much back lash. It has a four speed with 3:73s and an auburn posi. I ain"t set one of these up in years and am thinking of having it done but I hate paying for stuff that I think I should do.(squeak,squeak). Suggestions? Info, thoughts.
Thanks guys
Lance
Ps- You guys around St. Louis
if you know a good reasonable
place I'd like to know .
It could just be that the pinion nut backed off. If the nut backs off, it will allow all the problems you mention to happen. Befoer you get nuts spending a bunch of time and money trying to fix the thing, try just tightening the nut back to spec. That probably is all the problem is.
Randy (then you can spend a bunch of time and money if that don't work!!):eek: :D
I would also check the pinion nut. I have had two back off and the rear end will howl and clunk. The first time I took the rear end all apart and looked everything over and couldn't find anything wrong. The second time I tightened the nut back up and called it good. I would would pull the cover and give everything a quick look. If the lube looks clean and nothing looks broke I'd think you would be Ok. Wise Speed Shop might give you a hint on a good local place to have it done. They been around for about 30 years.
Good News
You guys are great the nut was loose. I am going to see if I can get a seal and put it in while I am in there a little cause I figure the wobble did not help the seal. Can anyone tell me how much torque the nut is supposed to have on it. Should I use a impact or give it all my buck 25 can dish out. Everything else looks great 90 w oil is clean. Got inside and even used a magnet.... NOTHING YOU GUYS GOT YOUR SHIFT TOGETHER
THANKS
Lance
THANKS
Lance
Rotating torque of 10-15 In Lbs for used bearings. Thats obviously with the posi unit out. It's the only proper way to do it (and you should really use a new crush-collar). You can try to do it with an impact gun (I have) but it's really a matter of feel and luck.....
