Got a question. I just got done putting a SSBCmanual disc brake setup on my 66 nova. It stops very well...... but during full on panic stops the engine will stall. I have a 01850 (600 vac) Holley carb w/ 283 V8, small cam that pulls 15in. of vacuum at idle in park (1000 RPM). I've got a vacuum advance mallory unilite. I'm wondering if gas could be sloshing in the bowl and causing the stalling, Note: Im just guessing the carb may be the problem since the car stops quicker now than it did with the drum brakes. And it NEVER had this stalling problem until I put the discs on it. Oh, and the floats are set to a little below the sight plugs. Ideas?
Mike Maxwell
Mike Maxwell
