That could be air still trapped in the system. Lift the car off the ground on jack stands. With the car NOT running, slowly turn the wheel left to right about 50 times with the cap off. Have someone watch the fluid level to make sure itr does not get low. You may need to do this more then one time. That should do it.
It will do that with the cap off!:devil:
69’ Nova.
thanks a lot, that sounds about right couse I just installed the system.I'l try that:yes:
