1 - 12 of 12 Posts
Has anyone removed the power steering pump and just used tubing to connect the two lines on top of the steering box? I was thinking of cutting the lines and leaving about 2 inches of steel tubing to connect them.
What are your thoughts?
· Premium Member
I know a guy with a blown SBC Camaro who just removed the pump and lines and didn't even plug the holes. Took me for a ride and didn't seem to have trouble steering but then again we weren't carving any corners.:eek:
Discussion Starter · #6 ·
I need a new one as of right now, and lines since they both were spraying all over the place. I am just about ready to put the motor/trans back in and I was debating on just ditching the ps all together.:cool:
lol i forgot to make the jumper and it became air bound, then i got a manual box, pitman arm and rag joint and all is well, just haven't gotten used to the slower ratio yet.
Discussion Starter · #9 · (Edited)
I know that a power box that is unhooked would be harder to turn than a manual. I've looked on this site for manual boxes but no luck so far.
I also have to buy a new PS pump as mine is shot so I thought of running without it for a while but that doesn't sound like too great of an idea.
Time to search for what years/makes of manual boxes will fit. (Unless you gurus feel like sharing some of that info now, I won't complain) :thumbsup:
The ratio for the power steering box is different than the ratio of the manual box that is why it is harder to turn. Power steering takes about two and a half turns of the wheel to go stop to stop where as manual is about seven turns.
I have manual in my 69 and I hate it especially when the car drifts sideways during a burnout, you have to do a lot more turning to correct it.
Where are you located, maybe I will sell you mine if it doesn't cost too much to ship it.
1 - 12 of 12 Posts
