got my motor running today finnaly:D)started the car up and the steering wheel started to turn by itself kind of violently (to the point you couldn't hold onto the wheel i have a power steering pump with resavoir
I need to replace my power steering control valve..And yes it can cause that problem...You can get a repair kit..About $17...or a rebuilt control valve...$80....$120...Your choise...
Vendor
If your car has a power rack and pinion I would say that you have the power steering lines reversed. The pressure hose goes to the small port on the rack.
Tim
steering problems!
I just read the thread about the lines on wrong and i did the same thing.
Ok another problem....the steering shakes bad when turning, but better one way than the other! I put on a new control valve thinking that was the problem but still does it! Do you think its the ram?? Really the only thing that is left. Thanks 67 nova
