Never played with the p/s on the early cars much. Matter of fact the only time I touched them is to swap it for a manual setup!
I have a cousin that has a 66 w/ some problems. The stud that connects to the pitman arm is is way to sloppy. Can they be rebuilt? Anyone know which parts to ask for or a place to find a good used one? What should I be asking for (power steering control valve?)
Hey duece,
I believe you are indeed talking about the stud in the Control Valve. The stud is held in place by a pair of "concave wedges" (sorry, I'd have to look up the real name) but is depress by a spring. None the less, rebuilding your control is pretty simple. Let me know if you need details, I have done a couple and have a semi-complete walkthrough.
-Brent Thomas
Ohio
Hey duece,
The spring I was talking about is #6 in the pic below.
-Brent Thomas
Ohio
Thanks...just ordered a rebuild kit from a Corvette supplier. The hydraulic side appears fine but, the ball stud is waaay loose.
Yes, I think the last I looked the corvette dealers have the rebuild kits cheaper then the couple nova dealers.
Did you buy a kit with a new stud or just a seal/rebuild kit?
(I think the stud is about 30 bucks)
-Brent Thomas
Ohio
After finally getting my car going three years later, I see I have a leak around the ball stud.
could one of you please lmk the part number for the rebuild kit.
Bob
Hey guys, I'm really interested in the best prices on parts to rebuild these units. I am also looking to source slave cylinder parts, especially the shafts and searls for them. I have one cylinder with a pitted shaft that needs replacement. Any info is appreciated. thanx
Jay,
I bought 3-4 Rebuild kts from a guy on ebay a couple of years ago, but then I found NAPA stocked them and just about all Corvette Part Houses have it for the same "fair price". As far as the stud, I think I only purchases one from C2O, because the treads where gone. (I'd like to help more on this, but am afraid that my post will be remove, if I start throwing out vendor names and who I have had luck with and not)
Anyway, as far as the Slave Cylinder, I don't believe they sell them and you'll be stuck with purchasing a new one, unless someone knows where to score the replacement parts?!?! Yes, you can buy the spring, seals, rubber kit, but a bent or pitted shaft and you are stuck.
-Brent Thomas
Ohio
