I'm having some issues with my March Performance power steering pump. The pump itself is a GM unit and the reservoir is made by March. I bleed the system as per GM and get all the air out. Works fine, no noise.. If I raise the RPM to 1,000 or more and turn the steering wheel most times it airates the fluid and I need to bleed it again.
My next steep is to replace the pump but, I want to make sure I use the correct recommend per fluid per GM first and rule that out. Anyone know what the correct power steering fluid is for a GM pump??
