control valve needs adjustment
The control valve needs adjustment. I bought a new one for my 65 and have a strong pull to the right as well. Motors Manual lists this adjustment procedure:
1. Disconnect cylinder rod from frame bracket
2. With front wheels off the ground, start the engine. One of the two conditions will exist:
a. If piston rod remains retracted, turn the adjusting nut clockwise until the rod begins to move out.Then turn the nut counterclock-wise until the rod just begins to move in. Now turn the nut clock-wise to exactly one half the rotation needed to change the direction of shaft movement.
b. If the rod extends upon starting the pump, move the nut counter- clockwise until the rod begins to retract, then clockwise until the rod begins to move out again. Now turn the rod to exactly on half the rotation needed to change the direction of the shaft movement.
Do not turn the nut back and forth more than is absolutely necessary to balance the valve.
This worked like a champ and solved my pull problem.
