101 - 111 of 111 Posts
We are not about locking everything down, but we do hold the members here to a high standard...We don't gamble anything here :rolleyes: losing a user or two that cause trouble seems to be a better payoff than losing a number of members that don't (from the same incident), and not to mention the volunteer staff that moderate this forum.
So, play as you will, and dig you own hole if you choose.
Well said Steve. :yes: There are too many sites out there that let things escalate and get ugly.
Back on Topic
In the early 70's my goal for my first RED67 was a 12 flat. Ya see around here back then most of my friends had 340 Mopars and 350ci Camaro's. A 12 flat for a 4 barrel street/strip racer was Par.:yes:
So I thought if my 330 went 12 flat I could be proud:cool:
The combo:
.030 over 327,,stock rods and crank.
Nova 362 2 bolt block
Angle plug heads 2.02 1.60
12.5 TRW Pistons
GK Flat Tappet 300/310,,,.518/.531,,,108
Chevy "0" Stamped Steel Rocker arms
56 Chevy rear sump oil pan
1 7/8" Kustom Fenderwell Headers:eek:
TM-1 intake w/2" open spacer
800DP Holley
5.14 12 bolt Posi
BW ST-10 2.64 wide ratio
9"X28.5 M&H slicks
Lakewood slap bars
weight 2947#
Made a few easy passes the first day in the 12.50 range.Seemed effortless.:sleep:
First WOT pass that day.............12.00 :D
So for the next few weeks we won some races at the track shifting at 8500rpm and running 11.90's & 12.0's
Then a good friend came over and gave me a lesson on "short shiftin". I didn't believe him,,,heck I was winning !
So I said OK, but the front bumper is going to hit the ground when it boggs in second gear. I mean hey,,this is a hi reving 327. LOL
Well,,,:eek:,,,a few quick shifts later...........11.55:eek:
"NO WAY,,it felt slow!" Back on the track I'm paying attention this time...........11.51 :bored: now I'm thinking. Shifting at 5500 first to second and couldn't keep it under 6500 second and third.:turn:
After rebuilding the engine for the next season with a 4 bolt block,,same combo,small journal with spacer bearings.............11.33 best with 12" Firestones and a little inner fender work.
Well, that's my 12 second combo story of nearly 40 years ago:)
:devil:
Let me clarify the roll bar comment I made. Anyone can run without a roll bar if they don't exceed a certain et. Running 11s and 9s as the captions on the pictures said is too fast for no roll bar and a cage by the rules of the major racing organizations. I am surprised any sanctioned track would allow that but it seems some do in some areas. Outlaw tracks with no insurance do around here but they are 1/8 mile and non sanctioned.
Joe your a smart man and know as well as I do that you can click off one or 2 passes before getting kicked for not having a cage .
Also as for your comment about grudge cars not being safe I have to call BS. Your grouping all grudge guys into that statment. BTW there are of plenty fo 25.5 and 25.3 grudge cars. You mean to tell me Stevie Fast,Chad Henderson,Mike Hill. SHAne Stack dont have safe cars since the grudge ? Thats like saying if you grudge you sell dope. LOL
I hope most folks got my attempted point. I'm not a lawyer so my written word may fail my thought and attempt to express them. No fast car is safe without a cage in it and most sanctioned tracks with insurance concerns will allow you to run if you exceed the ET rules for bars and cages.
1970 nova all steel no back seat.
Stock multileafs with comp engineering traction bars
Good bushings throughout the whole suspension.(afco front,solid rears)
8.5 ten bolt,33 spline strange axles,spool and 3:73 gears
Th400 with redneck 3000 stall 10 inch convertor
Trick front springs,Calvert 90/10's,lakewood 50/50 rears moved in the frame rails
26/10.50/15 et streets
396bbc with 9.5:1 compression,063 closed chamber oval port heads,Performer RPM intake,HEI with msd box wired to it,750 double pumper holley,.556 lift hydralic flat tappet comp cam,1 3/4 hedmann headers into 3 inch dynomax ultraflows
Ran a [email protected] with a 1.77 60ft time.This was its first and only pass.I had a tranny leak I have to get fixed and I will be back to try it again.
as stated you go thru tech with an normal looking street car on a small slick and stock int and the car looks like it runs 12's then you click off a 10.90 and they boot you out . THE TRACK DOESENT KNOW HOW FAST THE CAR IS UNTIL ITS RUN
K here goes not a 12 but very close.
1975 nova custom 3760lbs
356ci Chevy
Summit racing hypers
Stock rods with arp bolts
Stock cast crank 10/10
King aluminum bearings
Rings from federated auto supp
Summit racing vortec replacement heads not really a vortec have the intake bolt pattern of a vortec with. Standard runner pocket ported they flow 253 intake and 170's on the exhaust at .550 lift
I'm running steel shim head gaskets so my measured compression ratio is 9.98:1
Summit headers
Comp xe282hr
Scorpion rockers 1.6:1
Air gap intake with 650 vac speed demon carb
4.11 gears eaton posi with caltracs
Turbo 350 2600 stall
235/70/15 radial t/a's
Best so far 13.03 at 109mph 60ft was a sad 2.166
Got into 12.8s @ Little River with over 4000# '72 [ incl driver.] 400[.030 over] destroked to 352 w/lg journal 327 crank. Dome pistons , 75 cc AFR heads , ancient Aluma Kote 1 5/8 headers , 2.5 mandrel bend exhaust , EZ EFI 2.0 + dual sync dist [A Godsend!] ,on RPM manifold.R4L80[ProTorque 2400 stall] on TCI control CAN linked to EZ EFI.Orig 8.5" Diff W/ Eaton TruTrac , 30 spline Moser axles, 3.73, M/T 255-15 Drag radials, Cal Tracs, Car Still has workin Factory AC & power steering. AFCO Alum Rad W/Taurus elect fan asm moded to fit, Summit Elec Water pump. Areomotive 340 Fuel pump Kit in orig Tank . 93 octane. Driven daily and to/from track 110 miles rd trip usually with AC on. Has C4 13" frt brks using non-drop sealed brng spindles that required 17" whls.14-16 mpg
