This is long, but please stay with me;
I was lucky enough to score what I believe is a L79 short block and Winters intake off Craigslist. With the knowledge of this site I was hoping that someone can back up the research that I have done so far on the block/parts to verify what I found.
Here goes;
Block casting number 3791362
62-67 2 bolt Chevy II with recessed oil filter pad
Block date code J235
October 23, 1965
Deck Stamping FI209ZI
Flint MI, December 9th 327 4V 350HP with manual L79
My research shows Flint used I as a 1???
I have the VIN stamp but I am not posting it here. Sorry!
TRW pistons stamped L-2211A. Bore measures 4.010"
It has the correct front sump oil pan and dipstick tube.
It has a 8" finned balancer, stamped 3883961, and 137500. Date code of the balancer is L65. December 6, 1965.
The intake is an aluminum Winters snowflake, casting number 3890490.
What do you guys/gals think? Did I find something worthwhile? I didn't get the cylinder heads. What casting cylinder heads would have came on this engine? What date code(s) would be considered correct for this engine?
The problems are that the short block has sat without heads/intake for so long, the deck surface is rusted. I am soaking the cylinders and lifter valley now to try and free it up. I have not removed the oil pan yet.
I think I can find a machinist to deck the block up to the stamp pad as to save the numbers. I do not want to re-stamp if possible.
Sorry for the long post. Just had some questions and wondering about what my wife calls the "rusty" new engine in the shop.
Thanks in advance!
Here goes;
October 23, 1965
Thanks in advance!
