I found a posi that came out of early 70's camaro,10 bolt 8.5 ring gear. The housing numbers are 410408N, will these fit my 10 bolt? Where can I check these numbers out? What should I be looking for? The unit is GM part, are they rebuildable? Should I be concerned with worn pinion gears?
Thanks guys..your help is greatly appreciated!!
