1 - 3 of 3 Posts
Okay,
I took the back cover off of the now sold 12 Bolt rear I have. I am going to count the teeth on the ring and pinion and do the math however I found the following info on the ring gear:
E4H
1 GM 3853010 11 39 3 67
I am guessing this translates to a 3.55 posi that was made in 3/67
Am I right or do I still need to count the teeth?
Thanks!
-John
39 ring gear teeth and 11 pinion teeth. 3.55 I'll never figure out why people want to count the teeth when GM does it for you.
I figured as much....but if all else fails..count the teeth...sounds like i got the confirmation I needed!
Thanks 72VenturaII!!!!
-John
1 - 3 of 3 Posts
