John has really good information on his web site...here is a link to the fuel pump diagram. He also has diagrams for pressure regulators and return lines.Can anyone give me some pictures or info on how they hooked up their fuel lines from the fuel cell to electric pump? Fitting sizes would help alot. Im running the blue holley electric pump. "
-Thanks for the help
That -12 is huge. My buddy had his like yours on a low to mid 9 second ride. Same size with a -12 into the pump, then -10, and -8 to the carb.I would put the filter before the pump. If you can, what I would do is change the 1 outlet of the tank to feed the filter to be #10, then #8 after the filter. Mine is #12 to the filter and then #10 up to the regulator, with 2 #8's feeding the carb. You can use and most companies recommend, 2 #6's to the carb.
Good eye! :yes:You should not run that loop!!!!!!
I have been down this road many times.
The loop will cause a lock.
If the loop gets fuel spilled into it it will cause a liquid lock. And the tank will not vent correctly.
this has been proved and seen by me in marine applications.
It will work correctly in a role over, as it would without the loop.
Splash fuel into that loop and you have closed the vent. The fuel pump vacuum can not over come the lock.
The vent must pass air freely.
Be warned.
Al
Vapors turn to liquid.Thanks Al, but it's been in the car for 8 years with never an issue. I understand what you are saying for a boat, but in my car, the tank is never more than half full, and the tank is pitched back in the car so the vent is the highest point of the tank. The loop SHOULD be horizontal, so it drains back to the tank if that fills up.
That is what this is. 3200lbs Chevelle that has gone 9.0's at 148mph with a 540.That -12 is huge. My buddy had his like yours on a low to mid 9 second ride. Same size with a -12 into the pump, then -10, and -8 to the carb.
I'll add that to the list of things to do, since the car will be down for this year. Thanks.Vapors turn to liquid.
A hard stop and fluid can slosh in the vent loop.
It's not a good practice to follow.
Al
Nice set up BTW!!Talk about timing. I just finished this today. Here is what I used and a few pics.
Everything is Earls -8an
from the tank:
Tank -8 male
90 degree -8 female to -8 female
-8 male to 3/8 NPT male
Fuel shut off 3/8 NPT female to -8 male
-8 female to -8 hose
8" -8 hose to -8 female
Holley Blue (used the red for mock up)
3/8 NPT to -8 male
-8 female to hose
hose to -8 female
-8 male to 3/8 NPT
Fuel filter
3/8 NPT male to -8 45degree male
I will be adding Earls 85 micron pre filter just before the pump soon. This side is for the engine tomorrow I start the other side of cell for Nitrous will use the red pump there but the two systems will match.
