1 - 11 of 11 Posts
i need to plug the hole in the block where the old dipstick was,motor has a front sump on it now..any ideas..when i got the car the previous owner had the hole filled with silicone!
small welch plug would be the easiest.... drill and tap with a allen head set screw would be next.....
Last would be...(not preferred) clean the hole.... fill with a epoxy putty, like : Plumbers epoxy, or PC7.....
What wrong with the silicone?
Common way to do it.
If you find someone who purchase a GM crate engine with duel dipstick location, they may have the steel plug used for the drivers side dipstick. They come with a plug for both sides.
Or you could do like I saw the other day and just get a piece of wood dowel and drive it in there.:rolleyes:
Really, your local parts house should be able to get you a soft plug (looks like a little freeze plug) for a buck or so. Some of the small hardware stores will stock them as well.
small freeze plug!
x2
no need to tap it, thats just more work.
Clevite makes them, and you can go to napa/advance etc and get a freeze plug or expansion plug to fit perfect. Just set it in and use a punch to pound it in and seal.
I want to say 3/8 or 7/16. They are like 60 cents each.
I went through this with my v8 wagon 2 weeks ago.
1 - 11 of 11 Posts
