1 - 3 of 3 Posts
This is probably a dumb question...but I'm having problems with my original Delco-Remy voltage regulator.I have recently taken out the original straight 6 and put in a late 5.7 350 in my 63SS and I was unsure if I can loose it..or replace it with a better simplified aftermarket version?
Thanks.
Thanks.
You can remove the ext regulator if you upgrade to a newer internal regulated alternator. Some good reading here http://www.madelectrical.com/electrical-tech.shtml.
Look in the Best of Electrical use Big Al`s write up there it works perfect been running mine for 2 years now no problems ...
1 - 3 of 3 Posts
