I have been doing some research but I still have some questions.
My engine is newly built 350, it had a 305 before this.. guessing 300 hp now., stock metric trans., 3.73 rearend.
The tranny is starting to leak a lot so I want to replace it.
I need a:
700R4 (91 S10 maybe?)
TV cable
metric trans mounting bolts
metric converter bolts
aftermarket dipstick
torque converter form a 91 corvette(2000 stall stock)?
shorten driveshaft after install
move crossmember back a notch
new trans mount ?
I think that is it right or did I miss something? I can use the same flexplate? I think the 305 came with the 153 tooth but I am not sure. The 91 corvette seems to use the 153 from what I saw at the parts store.
Thankksssss
unless your getting an off the shelf trans.
i made sure i got all hardware included with the trans from the wrecker
I was thinking about getting a reman trans.
Oh yea, I forgot about the bracket. I have an adjustable bracket that is similar to the top one but I dont have the bottom bracket yet.
