Well I'm finally getting around to starting the restoration on my 63 SS convertible. Has anyone ever seen one like this? The only accessory code on the tag is 3X. SS option. that's it, nothing else. It is a 3 speed column shift and someone installed a 4 speed at some point. I was going to restomod this car until I discovered the casting date on the 194s block is F293 .June 29 1963. That is the day I was born. Ive since found the correct Saginaw 3 speed and column shift parts that were missing and have decided to restore this car back to factory original condition. It is originally black with black vinyl buckets . I know to many, it is probably a boring car in stock condition but I think the simplicity of it will be kind of cool and out of the ordinary. It is pretty solid as it came out of Eastern Oregon originally, Ive installed a new trunk pan and it will need lower quarters and a little work to the front floors. The rear floors , seat area and most of the underside still have the factory red oxide primer. The inner rockers (clamshells) are solid as well. I will be starting a build thread soon.
