1 - 13 of 13 Posts
Ok all, what is the difference in these and which is best to use? Putting my 383 together. I know it has to do something with differences in comp ratio, but i need some expert input. ALSO IM RUNNING TRICK FLOW ALUM HEAD 64CC COMBUSTION CHAMBERS. THANKS.
len
Flat-top:
Reverse Dome (sometimes called a dish but is a little different):
Dish piston (NOT reverse dome...No "Squish" pad)
Dome or "Pop-up"
As for which one is right for your build????? That depends on what you're doing with it and how much compression you want.:yes: There's several calculators available out there like this one that will help you calculate your compression.
http://www.kb-silvolite.com/calc.php?action=comp
The "BEST" is a different for different engines.
In the Small block Chevy the flat top piston has been proved to be the best.
A flat top piston with the small block head chamber design will provide the best flame travel. This is what is best for a SB, not the ultimate flame travel like found in a HEMI or Canted valve design head chamber. This is the best for a SBC!
Flame travel IE: Combustion chamber air flow can have a great effect on performance.
Compression goal has more important choice of the piston design.
Example: Based on same compression with both combinations.
A Flat top with a small chamber head will out perform a Pop up with a large chamber head.
Why? Flame travel, piston is lighter.
This is on a SBC, In some other type engines this is not true.
IMO
AL
383. with flat tops can make anywhere between 11.0:1 and 10.5:1 or higher depending on prep, and gasket.. with 64cc heads
Discussion Starter · #6 ·
i just figured outr my heads are 62cc comb chamber. would this make a huge difference? Will I be able to run pump gas 93 octane?
Len
Len
How much compression you can run with pump gas will depend on a LOT of things. Quench/squish distance, cam specs, intake style, Torque converter, gearing, how low of an operating temp you intend (and can) run, and most importantly HOW WELL YOU CAN TUNE IT!!
Discussion Starter · #8 ·
I spoke with the engine builder ( wheeler power products) and they advised to go with the forged dish piston with my heads which will put the compression around 10:1. Thanks
len
I have an engine builder friend with a dyno--he likes tiny chambers, and if you need less compression he likes inverted domes. He found a lot of power in a boosted application compared to the same engine with a flat top/larger chamber combo. On a big budget project he'll have the pistons made to mirror the shape of the chamber.
My 410 has flat tops and 64cc heads and is just about 12-1.
91 octane pump gas is what we have in So.Cal. and that's what I run.
You say boosted?
Blower application?
Seems this might be good for NOS!!!!!!
I would like some info on this deal!!!
Who's doing the pistons?
Al
Len
Good question, how much will it increase the CR from a 64cc chamber. FYI, I have eddy aluminum heads (RPM performer) with a 64cc chamber and Manley flat top pistons. CR is 10.5:1. Not bad at all for pump fuel, I do have EFI so that helps a lil. JR
You say boosted?
Blower application?
It was a Vortech blown 383 in a 5000lb. van that ran 11's--The 39° air temp inside from the A/C was nice in summer too!
I think he used JE at the time. I just read a story from JE in the new Chevy High that came today-says kinda the same thing about inverted domes.
Got my CHP today, I guess I need to open it up!!
Al
1 - 13 of 13 Posts
