I am currently trying to weld in my motor mounts, so I am making sure the transmission has the correct angle to it. I have the car up on stands, and I am using 2x4 to simulate the driveshaft. The transmission is loosely bolted to the crossmember, and the engine is supported by a hoist. The angle of the driveshaft is 5 degrees up (front higher than back). Currently the transmission pinion angle is 2 degrees up, giving me 3 degrees . Does this sound normal? If it is right, then I believe I just have to make my rear pinion angle about 1.5 degrees up to put everything within specifications. Is any of my thinking wrong? Any advice would be greatly appreciated as Ive never done anything like this and ive prolly spent about 3 hours now just staring at my car with numbers spinning in my head, and I havent even begun prepping the mounts.
