1 - 18 of 18 Posts
As some of you know, I've been fighting a traction issue with my car. After talking to several companies and some stock suspension guys, I decided a change was necessary. I took my car to TRZ Motorsports in Kissimmee for a coilover install. My Heidts front clip previously had a separate coil spring and shock (Mustang II style). I had 2 inches of travel. John Calvert explained to me, I needed at least 5 in. of travel to make optimum use of my Caltracs. The travel has now increased to 5 inches and I'm hoping for a marked improvement in weight transfer and traction. The guy at TRZ said it may be too much but, the travel can be shortened. I have also been told, a rear double adj. shock is still needed. Can't swing that right now, have to wait. I pick it up tomorrow.
my car
was alot more stable going down the track with only about 1.5 inches of wheel travel. Felt like i could take my hands off the wheel and put it on cruise it helped it so much. Really brought in the reaction times too. Went to a solid .05-.005 depending on which converter i had in it.
I wonder if sliders would eleviate the need for so much frontend travel ??
Any stock suspention type car NEEDS a minimum of 4.5" of front travel to make the suspention properly.
Stock suspention cars work on the premise of seperation not squat as a 4 link or ladderbar car does and to make that work effectively you need that front end travel.
I have sliders.
That's what everyone's been telling me. I tried everything else I could think of. We kept taking power out of the car to make it hook. The 1.48-1.50 60ft. times were just ridiculous. What's the sense in having HP and not being able to use it? Hopefully, that will change.
How much pinion angle? Mine will go from blowing the tires away, to dragging the bumper just by adding a few degrees. I need at least 4° down.
Exactly....
Most leaf spring cars I set up have from -5* to -7.5*
We are set right now at -5 degrees. I'll start there and see what happens.
Try the new front coilover setup and if still fighting it I would bet that a -6.5* in your car would work well:yes:
Discussion Starter #9
I have pinion shims to change it. I'm guessing that number has been successful in a car that you dealt with? I up for trying anything. I did pick the car up yesterday. TRZ Motorsports did a great job. I'm very pleased with their work.
I don't think the Cal-Trac's need as much as a slapper bar, but I ran 8° with my old set-up, and 4° is as far as I've needed so far with the new. When we did the mini-tub it removed 100lbs off the car; I put that 100lbs in the trunk and she stood right up! Without the weight it was doing 1.35-1.37 60 fts. on old slicks.
If my car was running I could do more testing! Maybe one of these days?
your perches
did you make those perches yourself ??? they look pretty neat.
just curious do you have any footage of your car leaving or running at the drags i just want to see it hall rrss :yes: :devil: :D
Discussion Starter #14 (Edited)
I hope to get some video of the car with the new setup. I'd like to see it myself.
do you measure the pinion or the drive shaft angle also ?
oh your ugly
You take the angle of both the driveshaft and pinion and substract the two. That will be your final pinion angle.
Dale (teddisnoke) designed them; they need to be made of a slightly stronger material--I tend to overtighten my U-bolts, and bent the perches because of it.
Discussion Starter #17
I got the car fired again yesterday. I plan on heading to the track on Friday night to try out the new changes. I still need double adj. rear shocks to complete the suspension but, I'll have to see how the single adj. work out. It was 102* temps here yesterday. I'm not sure how the track conditions will be. It will be fun to get out there again.
Cool but PLEASE don't forget the video camera.:yes:
1 - 18 of 18 Posts
