Has anyone read Vizard's cam design article in the July 2006 edition of PHR? The concepts are intriguing.
I'm helping my dad select a solid lifter cam for a street/strip '66 fairlane powered by an FE 428. If I use the recommendations in the article, I come up with the following:
Advertised duration between 280-290 degrees
Lobe separation angle between 103 and 104 degrees.
Idle quality isn't much of an issue in our application. However, installing a cam with a 104 separation and that much duration just seems wrong. I'm curious if it would even idle below 1,500 rpm.
Any thoughts?
Any thoughts?
