Does anyone have pictures of the routing of the parking brake or emergency brake cable routing for a 66 Nova? I have the old cable in the trunk and need to know how to route it
Yes Thank you this helps! The cable under the muffler routing is still an unknown.
it does look as though it runs under the muffer/pipe. i was just under the car while it was up on jack stands doin an oil change grease job. i could go look under the back, what is it your looking for ?
okay i would have to use my digital cam an then load to the hard drive then up to here. so i'll try to discribe the route. sure was cold on the floor. from the bracket it goes under the leafs to the drivers side. from the braket to the pass side it routes in front of the gas tank an under the leafs to the brake backing plate also the cable to pass side is routed at the back of that side muffler.
I thank you very much for your help. This will help me figure it out big time
