1 - 11 of 11 Posts
I was driving in the Nova yesterday to a car show, doing about 70 on the freeway and the temp was running about 185* which is normal. As I exited the freeway the temp started creeping up. After about 1 mile it got up to 220*:eek:
On the drive home it seemed fine, but then after about 5 miles it started doing the same thing. as long as i'm moving it's o.k. As soon as I slow down or stop is whem the temp starts to go up
I have a mild 383 with the Summit universal radiator, Derale 17" fan with a shroud, fan comes on at 180*, off at 170*, Edelbrock water pump, and a 180* thermostat and a 16# cap.
I've been running this cooling set-up for a while (9 months) with no issues at all.
Does this sound like a bad thermostat or a bad water pump?
If it only seams to heat up when movement is slow, it would seam to be more of a fan issue. Lack of air flow.
If the water pump or thermostat was not working, it would always be hot.
Is the radiator full? How about the shroud? Is the fan placed properly in the shroud? The fan blades should only stick about 1/2 way into the shroud. Are the sides of the shroud sealed off?
Radiator is full
Electric fan mounted on a 66RICH shroud
Put a pressure tester on the cap and on the radiator to see if theres a small pin hole.
That was the first I checked after checking the coolant level.
The thing that has me puzzled is, I drove it last weekend and it was fine. I probably have about 1000 trouble free miles on the radiator/shroud/fan set-up. This just kind of popped up all of the sudden. I'm gonna check everything over again and make sure I'm not missing something simple.
Hey Bill,
Are you sure the fan is operating? Could it be intermintant? Maybe check over your fan wiring or temporarily (sp) splice in a test lamp that you can see inside the car. Wire the light in parallel with the fan motor. If the fan is running the light will be on.
Ron
Discussion Starter #9
The fan is coming on. When it first started getting hot I pulled over real quick, popped the hood , and verified it was on.
I pulled the thermostat last night and it appears to be bent.
Here's what I think happened.
I think the thermostat stuck causing the temp to spike. I'll pick up a new one today and check it out, then go from there.
Then on the drive home from the show, although it got hotter than normal, it didn't pass 200*. I'm assuming that might be due to the slight loss of coolant from the initial overheating.
Like I said earlier, i've been running this exact set-up for about 1000 miles with no problems at all. In fact this is the set-up that was on it at the John Force show and that alone was a 220 mile round trip, plus the car was loaded down on that trip.:confused:
I'll keep you guys posted.
Discussion Starter #10
Fixed
Went and bought another thermostat, same brand a previous one. When I opened the package it looked worse than the I took out of the car that I suspected was sticking. So I returned that one and bought a 180* Stant Super Stat.
Let it run in the garage for about 1/2 an hour, then drove it about 30 miles and the needle didnt get any higher than 180*:D:D
I love it when it's a simple fix:yes:
Simple is always nice, I had a 71 El Camino with a bb which had similar heating problems. A new big ol' alum rad, new fan and shroud, new thermostat and a additional electric fan later and it ended up being a broken impeller in the water pump (which was not even 6 months old). I often get frustrated that my dog cant talk to tell me whats wrong or what she wants...perfect analogy for classic cars.
1 - 11 of 11 Posts
