I can collect all the good answers and merge them into a "Best of" thread if someone wants to search them out and post the links here.
Thanks guys for posting and Paul, I tried to get a broad spectrum of "overheating issues" and came up with these to start with. I also scanned the "Best of Tech" and there is nothing there.
http://www.stevesnovasite.com/forums/showthread.php?t=36323&highlight=overheating TPI motor with heating issues
http://www.stevesnovasite.com/forums/showthread.php?t=40117&highlight=overheating Radiator cap pressue question
http://www.stevesnovasite.com/forums/showthread.php?t=43153&highlight=overheating Thread on mecanical aluminum water pumps
http://www.stevesnovasite.com/forums/showthread.php?t=43484&highlight=overheating Overheating when switching to a higher rear end gear ratio
http://www.stevesnovasite.com/forums/showthread.php?t=45022&highlight=overheating 10 things to cover when doing your cooling
http://www.stevesnovasite.com/forums/showthread.php?t=51532&highlight=overheating Electric fan CFM rating
http://www.stevesnovasite.com/forums/showthread.php?t=54428&highlight=overheating Overheating issues
http://www.stevesnovasite.com/forums/showthread.php?t=56801&highlight=overheating Billet crank pulley and cooling
http://www.stevesnovasite.com/forums/showthread.php?t=56576&highlight=overheating Keeping a big block cool
http://www.stevesnovasite.com/forums/showthread.php?t=65943&highlight=overheating&page=2 Timing issues resluting in a overheating issue
http://www.stevesnovasite.com/forums/showthread.php?t=70383&highlight=overheating Trying to keep temps under control
http://www.stevesnovasite.com/forums/showthread.php?t=71754&highlight=overheating 160 or 180 thermostat
http://www.stevesnovasite.com/forums/showthread.php?t=97829&highlight=overheating Overheating does not stop
I am 1/2 way thru the history of overheating....
Hold on, here's more.....
http://www.stevesnovasite.com/forums/showthread.php?t=99726&highlight=overheating Cooling experiment
http://www.stevesnovasite.com/forums/showthread.php?t=98731&highlight=overheating Thermostat for big block engine
http://www.stevesnovasite.com/forums/showthread.php?t=99067&highlight=overheating Radiator/fan size question
http://www.stevesnovasite.com/forums/showthread.php?t=109503&highlight=overheating Debat on how to solve an overheating problem
http://www.stevesnovasite.com/forums/showthread.php?t=24850&highlight=overheating Taurus Mk VIII fan
http://www.stevesnovasite.com/forums/showthread.php?t=120837&highlight=overheating Trying to choose an electric fan
http://www.stevesnovasite.com/forums/showthread.php?t=117122&highlight=overheating Getting warm at highway speeds
http://www.stevesnovasite.com/forums/showthread.php?t=125860&highlight=overheating 400 sbc getting hot
http://www.stevesnovasite.com/forums/showthread.php?t=46705&highlight=overheating Summit Radiator & Black Magic Extreme Fan
http://www.stevesnovasite.com/forums/showthread.php?t=126419&highlight=overheating Flex fan vs stock clutch fan
http://www.stevesnovasite.com/forums/showthread.php?t=127372&highlight=overheating Coolant comming out of the overflow
http://www.stevesnovasite.com/forums/showthread.php?t=130561&highlight=overheating 1st gen running without a fan shroud and the issues that followed
http://www.stevesnovasite.com/forums/showthread.php?t=126528&highlight=overheating Engine running to cool?
http://www.stevesnovasite.com/forums/showthread.php?t=130514&highlight=overheating 3rd Gen overheating issues
http://www.stevesnovasite.com/forums/showthread.php?t=152367&highlight=overheating 502 running hot
http://www.stevesnovasite.com/forums/showthread.php?t=150643&highlight=overheating Getting hot on the freeway
http://www.stevesnovasite.com/forums/showthread.php?t=152658&highlight=overheating "Help, I am running to hot" thread
http://www.stevesnovasite.com/forums/showthread.php?t=154604&highlight=overheating BBC still running hot
http://www.stevesnovasite.com/forums/showthread.php?t=140445&highlight=overheating Mechanical vs Electric fan
http://www.stevesnovasite.com/forums/showthread.php?t=155616&highlight=overheating 350 overheating
http://www.stevesnovasite.com/forums/showthread.php?t=156033&highlight=overheating 468 BBC overheating in a 1st Gen
http://www.stevesnovasite.com/forums/showthread.php?t=156051&highlight=overheating Which electric fan for overheating issues
http://www.stevesnovasite.com/forums/showthread.php?t=156044&highlight=overheating 327 overheating issues
Now, this is not ALL of the overheating issues but a broad spectrum of issues that have been posted on this site.
Hopefully, someone will find these threads to be usefull in the future.
