I have a 71SS numbers matching, but for some reason after 3 years, I’m suspect whether or not the 12 bolt I have is original to the car. Even under all the undercoating and years of grease and grime, the red posi tag is still attached. I thought I read somewhere the 71 and 72s received 10 bolt posi units. Thoughts?
Check https://www.novaresource.org/
87gn, In car applications, the Chevrolet 12 bolt, was used up to 1971. The code info can be found on the passenger side axle housing. There are plenty on-line sources to decode your information. It is very likely your 12 bolt is original to your Nova. Hope this helps.
If you clean the axle tube at the front/passenger location, you should be able to read the date codes. If they are correct for your build date, it's a match.
