Ordered and received a grille filler panel for my 66. If you look at the end surface the oem piece is perpendicular and the repro is on an angle. There is no way to bolt this up correctly and the center-to-center from the hole to protruding bolt is off at least the diameter of the hole in the sheetmetal. Are all of these that bad and what if anything can be done short of cutting it and re-welding it? I guess I shouldn't mention which vendor I bought it from at least not yet. Anyone else have this problem? -Bob
