1 - 11 of 11 Posts
ok im thinking about buying a 327 4br out of a 67 impala i was wondring what the power rating is on them stock. ohya it only has 50,000 miles on it. and what cheap upgrades i could do to it thanks.
In Canada I think the only one offered in 67 was a 275 horse 327. I really like them, great setup.
As far as upgrades, I wouldn't change a thing if it was mine, but many on here will have advice for you I'm sure:D
Carl
The first motor i had in my car was a 327 and i loved that little motor, i actually have plans of pulling my 406 and putting it back in the car! as for mods i put a set of 2.05/1.60 valve camel humps, an rpm air-gap man., 5.18/5.36 lift cam, and a 700 holley double pumper on it and it went 12.67 in the 1/4
It sounds like a crane cams solid to me....thats a pretty big cam for a 327....I'm sure it ran like a stuck pig at the top end.....:cool:
IF i'm right...the specs are .518/.536lift with a duration @.050" .244/.252
I have the same cam wrapped in bubble wrap in the one drawer of my tool box..:)
My first 67 Nova had a 327 and when we rebuilt it for the drags (1973) we put the first gen angle plug heads on,an Tarantula intake, 800DP holley, and a General Kinetics cam;.518 / .531 , 300 / 310 solid.With 5.14 gears and slicks it went 11.30's @118mph.
What a fun ride,,,seems like yesterday.:D
Must be a popular lift and duration combination.
RED67:chev:
so i could get some good hp tq from a 327? with just a few mods. about how much do u think it would cost?
327
im picking my 327 up tomorrow had to bore 40 all new piston rods polished steel crank,balanced
all new valves springs and valves on double hump heads complete engine
job minus intake and carb 2000.00
327's Rock
First off.......... most here on the board will tell you, more bang for the buck if you go with a crate 350 or rebuilt a 350 !!!!!! What year is your Nova?? I decided to go with the 327 because I was doing a Cloner 66 Chevy II L79 theme!! I located a ZI block (one of app 180 shipped into Canada !!) But that's it !! A .040 bore, Dart Iron Eagle heads, SRP pistons, Comp cam & roller rockers, balanced, "490" intake and 3367 Holly carb!! Thru Dougs 2&1/2 inch headers and I'm thinking somewhere around 400hp! It all depends what you want to accomplish and for what?? My engine costs were a little more than what I expected, as I didn't assemble this one, I had it built !!
Hope this helps?? Bogie
Discussion Starter #10
my nova is a 78 2dr th350 with shift kit 2500 stall 10bolt 4.11 richmond gears and a minispool its a weekend drive that i take to the track it was pretty quick with a 307 that was a mild build up. but im looking at a 327 right now that a buddy has in his garage its pretty well built when he had his camaro on the dyno with it it was a little ove 400 hp and 425 tq he ows me a fav for somebody work i did for him and gave him some camaro parts he said he would give it to me for $500.
Jump on it like a frog on a junebug.
1 - 11 of 11 Posts
