1 - 3 of 3 Posts
finally fixed electrical problem. Now another problem the oil pan is for a 194
6 cly, but not for a chevy II. So i'm running into a problem getting a used oil pan for this 62 wagon. Any help getting one or a place to get it.
thanks
So you're needing a chevy II center sump pan for your 194 and not the rear sump you currently have?
If so, You will also need the oil pump pickup tube and dipstick.
If your block is a non-Nova block, you will have to relocate the dipstick hole to the middle of the block next to the fuel pump.
I have these parts, if you need em.
PM me if you're interested.
PM Sent.
Sounds like the engine is not an original Nova block.
Send us the engine numbers off the side of the block and we can tell you what it is.
You didn't say if the engine was still in the car. If not, you'll need Nova 6cy engine mounts for the block.
1 - 3 of 3 Posts
