went to start the car back up today, and its got oil coming out of the breather, not just blow by but actually oil. any one know why?
are you just running breathers or do you have a crank case evac. system of some sort. you need to have a pcv valve hooked up or a pana-vac system to help pull the crankcase pressure out. if you dont you will get oil up into you gromet/breather and the C.C. pres. will force it out.
the actual oil is accumilated oil in th e filter if you want to get rid of this problem i would install a pan e vac system it will pull some of that pressure out of the crankcase
