i have an oil leak and it appears too be leaking from around the starter like it drips from there andy thougths on this
no valve cover leaks and dip sticks on the other sideWhat side is the dipstick on? Also may check valve cover gaskets?
Where do you purchase this and is it safe to put in your oil? I would guess you would need to do an oil change afterward?Leak check dye will eliminate all the guessing.
