1 - 1 of 1 Posts
Really only a Spot of oil....Really makes me wonder what I might have to do...after driving the 66 327 newly rebuilt for 1/2 hour or so...I get a spot of oil about the size of a quarter...I tried to take off the bellhousing cover but the oil filter's in the way to take the last bolt out....Now I have to wait till I change the oil again ..Unless you think I can save the oil I just put in and reuse it ...Damn leak anyway..When I installed the rear main seal I offset it about 3/8 of an inch, so I really don't think it could be the rear seal...If luck is with me..It's the oil pan gasket...Any thoughts ??..The oil is dripping from between the cover and the bellhousing..the flywheel's dry ( no Oil )...From what I can see with a flashlight...And the end of the crank is dry also...From what I can see....
1 - 1 of 1 Posts
