1 - 10 of 10 Posts
I have a small oil leak (a few drops after the car sits overnight), and am certain it is coming from the drain plug. I have been using a nylon washer and replaced it with a new one when I changed the oil a couple of months ago. I will be changing oil again soon and am looking for a something that will fix this annoying leak. What have you had the best success with?
I have good luck with copper washers. You may want to be sure the oil pan surface is flat with no burs or not allowing the plug to seat itself correctly.:yes:
You could even try some teflon tape on the plug.
Never use teflon tape on any oil or fuel thread. :no:
All it takes is for a small piece to come off (and it will), get into the fluid and end up in the pump and/or system and you'll have much bigger problems than just a little leak. :yes:
gm dealers have nice copper washers with a rubber center. they work great.
^ ^ ^ This is what you want. ^ ^ ^ :yes:
I use the nylon washers but these really are the best. :yes:
If it doesn't stop leaking with a new washer, it's possible that the pan has a small crack in that area. Happened to my brother in law. He put a new pan on it. Just sayin. Dave
1 - 10 of 10 Posts
