Not Nova, my 94 GMC Truck. OEM everything on the truck.
Replacing Head and Intake gaskets due to coolant leak. The original intake gaskets had a Block-Off plate on each of the rear coolant ports. Each plate has small hole. New intake gasket is solid with no openings for same locations.
Do I :
Put the plates back in and solid gasket over them?
Put the plates back in and add small hole to gasket?
Leave the plates out and open up the gasket?
What the basis of the rear coolant ports being blocked off. The intake does have a rear connection to heater core, is that the reason? But, driver's side was also block off. ??
Picture of plate below.
Do I :
