I've been chasing a vibration coming through the steering column on my 66 ever since finishing my muncie swap and I'm starting to narrow it down to a combination of, i think, two things.
I think my headers are contacting the pitman arm or sitting very close to it which would explain why it seems to get worse at steering lock and could explain why it is most pronounced at a certain RPM regardless of speed, gear, or if the car is even moving.
I plan on correcting this with some "persuasion" from a hammer when I remove them shortly to rebuild my upper control arms.
I also assume my motor mounts are partly to blame.
I realized there is a ton of space between the frame mount and the flange on the motor mount mount. I assumed I used the short and wide style vs the tall and narrow until I measured my frame mount.
The frame mount is just shy of 2 5/8" from side to side which should be the short style mount I believe since the tall is supposed to be 2 3/8". The weird part is the ears on my motor mounts seem to be somewhere around 2 3/4" or 2 7/8" apart...
I have washers in place now as a temporary solution but I'm going to be ordering new mounts (probably the Summit Poly ones) and it looks like the short and wide style is correct.
Here's my question.
As far as I know there are 3 styles of these mounts. The two I referenced above and a 3rd, oddball size that was 2.5" ear to ear according to a few sites I've found like this:
http://www.pozziracing.com/camaro_engine.htm
If that's true then what the heck are my current mounts from? Does anyone know of an early chevy style mount that would be that wide?
Thanks!
hotrod
Here's my question.
Thanks!
hotrod
