I have been a 'lurking' member for a while. The time has finally come that I need to put some love (ie $$$) into my 66. I purchased the car back in 2008 and have been enjoying it for what it is stock suspension, steering and lack of power ;-)
It currently has:
- 4 wheel manual drums w/ 'widow maker' manual single master
- leaky factory power steering
- Griffen aluminum radiator
- stock suspension on its way out
- 350 low compression truck motor (cyl 4 is now gone)
- small valve iron heads
- edelbrock 650 carb and performer intake
- headers that don't fit and are dented in to make fit
- 2.5" exhaust
- TH350 that leaks big time
Basically, the car needs a good over haul. The body is in fairly good shape with the exception of some bubbles along the drip rails and passenger fender.
Being that i enjoy driving my car more than showing it, i am a %75 function and %25 form kind of guy so the body work is really not a priority to me right now.
The more i get into this car, the more i realize that i want to do it. I am seeing Pandora's box here big time. I have a limited budget, so i want to make sure that i am spending my money in the right places and in the right order. I refuse to do things twice so if it means spending a bit more to do it the correct way one time, then i will do it, however i have a limited budget. My goal is to have a car that is used for %75 street and %25 road coarse / strip.
Right now I have pulled the motor/tranny and decided it isn't worth doing anything to. In doing so, i have also discovered that the chassis wiring harness is a fire waiting to happen, steering needs help, brakes suck and the list goes on.
I am looking for guidance on where i should be focusing on, where i should be spending my money, where i can potentially wait etc.
Here is what I am thinking in order of priority:
1. CBR front steering/suspension setup w/ single adjustable Coil Overs & sway bar
2. AAW Chassis Harness
3. CBR LS Brake swap
4. LQ4 Swap (i havent decided about Manual or Auto Trans, im leaning towards T56)
5. CBR LS Headers
6. Some sort of 17" or larger wheels
7. L92 heads and Cam Upgrade
8. CBR 3" Exhaust
9. CBR rear 4-link
In order to get the car back up and running ASAP, i am thinking that i will only be able to do 1-6 this year and 7-9 later.
I need some thoughts on what to do with the:
- brake setup
- Radiator
- Gas tank/fuel pump
- fuel/brake lines
I know there are things here that i haven't thought about and need to consider and i welcome any thoughts. Right now i am overwhelmed because i was hoping to do this build in phases, however, it seems like i need to do it all at once in order to do it right.
Can anyone provide any guidance, insight or general words of encouragement? I just need a solid plan that i can work towards one step at a time...
Here is a pic:
It currently has:
- 2.5" exhaust
5. CBR LS Headers
8. CBR 3" Exhaust
9. CBR rear 4-link
- brake setup
- Radiator
- fuel/brake lines
Here is a pic:
