What else should be done to the car?
1 - 20 of 42 Posts
nutcase - YEAR MODEL
Year: 1970
Model: Nova SS
Engine: Engine 406 4 bolt .30 over 11.2:1 Compression
Camshaft Isky RR-615 260/268 @50 302/294-615/617 Solid Roller Lash .026-.028 hot lobe center 106 deg
Cylinder Heads Dart II Sportsman 2.080x1.600 7 deg spring 1.25x1.75 –valve locks 11/32 x 7 deg (intake 200cc+ Ported bowl blend)
Rockers Lunati 1.6 Roller
RODS Eagle H BEAM 6 inch rods
Pistons JE Flat top 2 value release pistons
Ignition: MSD 6A with HEI distrib/coil (Curved)
Induction: Holley 4150 870 cfm Custom Race Carb
Manifold Eldebrock Super Victor port matched to head
Body/Exterior: Lexus Metallic Blue/Cowl Induction Hood/ 73 Nova Doors
Front End: Braking POL 1" Bore Manual MC/Prop Valve 4 Wheel Disk Brakes
Transmission: Turbo 350 with 10 inch 3500 stall converter & shift kit
Rear End: Sutton Engineering 10 bolt 8.5 Eaton Spool with Moser Axels and Clip Eliminators. 4:10 Gears
Exhaust: Headmen Hedders 1 ¾ inch, 3 inch exhaust oval port with Race Ready 3" Cut Outs
Wheels/Tires: BFGoodrich g-Force T/A Drag Radial Tires P 275/ 60-15 (28x10.8)
Interior: Custom Seats/Console, 4 Point Seatbelts, 8 Point Roll Cage, B&M Hammer Shifter
Fuel System: Holly HV Pump 130 GPH Stock tank and fuel lines.
Suspension: Caltracs Bars and CE sub frame connectors. 90/10 front 50/50 rear
Cooling: 180 Thermostat Stat heavy duty / Be Cool Aluminum radiator/Flex-o-lite BM Electric Fan
Braking: POL 1" Bore Manual MC/Prop Valve 4 Wheel Disk Brakes
Sound system: Pioneer 150W Stereo
Additional Comments: Isn't she one BAD *** Ride?
I wouldn't touch wheels and tires but I'm still old school. I chose Covan dash because they are never done! Car if pretty much perfect to me :yes: although everybody could nit pick something.
Sounds evil man!
DON'T DO THE COVANS! Just mod your own panel like this:
And get some Caltracs!
Upgrade to a rev limiting ignition!
I would upgrade to a 6AL box, so when those drag radials break loose on the street or track you don't blow the motor up. Good investment in MHO. Nice ride. I have the cutouts on my 77 and 78 with Warlock mufflers. Very fun on the street.
Dude that car is [email protected]****!!!!! I wouldn't do anything to it but DRIVE IT TILL THE WHEELS FALL OFF!!!!! my old 70 may or may not have been as nice as yours but I wished I had painted my 70 blue. Sweet car!!!!
Like the car but I would go with some drag stars and white letter Hoosier tires. Keep the slapper bars they look cool. Covans dashes look like poo tho car wasnt maent to have round gauges they look awkward.
Your car is super sharp!:cool: I had Weld draglites for my car as well. I sold them and i am ordering a set of Billet Specialties street lite wheels Friday. Hope i made the right decision.
1 - 20 of 42 Posts
